Bleeding 2014 1.6tdci fiesta coolant system
Hi all,
Had oil cooler failure i think on my fiesta so i changed the oil cooler, radiator, thermostat and expansion tank as they were all gunked with oil.
ran coolant flush a few times
Now ive refilled the system to max line and left it to run for 45 minutes with expansion cap off and it reached 3 bar on temp gauage, eventually, but wouldnt reach full temp (4 bar i think is normal?) to allow the thermostat to open up.
Gave up and took it a quick run with tank cap fitted, it went up to 4 bars, came back to house and it dropped to 3 again.
im guessing the system has alot of air in it but im struggling now.
Im getting heat through vents
any suggestions?
thanks
11 hours ago, LCR1993 said:
Hi all,
any suggestions?
thanks
Is the coolant being pushed out of the header tank/ or is any water leaking out of the cooing system since the repair ? There will be a pressure relief valve on the cap of the header tank if you get excess pressure in the system. The thermostat works with water temperature , from your description of the vehicles heater working seems like the thermostat is opening ok . If you leave the vehicle’s eng running standing will the cooling fan cut in an out ?
