diag socket location
I have a 2002 KA 1.3. Can anyone tell me where the Diagnostic socket is(if there is one), Its not the fiat 500 type ( to the right of the steering column) and its not in a recess in the carpet by the LH or RH kickpad. This is a demo/test car not on the road so currently has no doors on and dash is partly stripped so easy to see around.
Looks like an ECU at LH kickpad /doorpost,with a  black cover but still cant seem to see diag socket.
any help would be appreciated
It should be passenger side footwell right next to the door.
Will check again monday cheers
If the carpets still in the car , then there's a little oblong shaped piece of carpet you flick out the way to access the obd port.
Just googled and got vid showing it. Screen shot the appropriate bit
