Soft clutch pedal
Soft clutch pedal is there a fault with it I have 2017 edge sport
Is it soft from the day you bought it or it became soft recently?
I think that you have to check the clutch's oil tank for refill.(Every latest Ford have a Hydraulic clutch i think.)
You must have to check it immediately to a mechanic or your clutch is going to have a damage. You will not be able to shift any gear at all!!!
In the other hand, i hope that your clutch is so soft from the factory so it will be no problem at all.
Greetings from sunny Greece!
I was going to say I hadn't noticed the clutch being soft ... but then mines an Auto ! 🤣🤣
So is mine.
No its just went soft tried bleeding the clutch but still soft grrrrr
