Edge towbar electrics
Hello,
I'm looking to purchase a 2019 edge and get a genuine ford towbar and electrics. I've seen some posts saying you need an additional 2wire harness for the Fridge/ATC. Is this for aftermarket dedicated electrics. The electrics on the ford site says it comes with permanent supply's and i can only see the 1 kit
Neil
This was the tow bar my local Ford dealer fitted when I ordered a tow bar from them, so not the 'official' Ford one, but one they always install and guarantee as their aftermarket offering ...
It uses the genuine Edge specific wiring kit (i.e. 13 PIn with Genuine Ford 'Trailer' ECU) ...
and that also needed the 'Extension kit' to provide the ATC/Fridge power feed, diect from the battery and  switched by the cars ignition ...
All ECU's coded by the Ford garage after install.
Thanks Simon,
That's good to know about that kit.
I'm wanting to use the ford TCM and electrics and trying to see if it supports the permanent live connections or you need additional wiring
Cheers
These kits use the actual official Ford TRM, so I would expect the harness to be wired exactly the same whether it's aftermarket sourced or direct from Ford.
