Dash Cam Hard Wiring?
Hi Guys,
I have a Ford Kuga 2019 Titanium.
I am fitting a Thinkware Dash Cam F800 Pro dual camera (one at the rear)
I am no electrician and am easily confused.
I need to know which fuses to attach my fuse Taps to??? 1 x ACC and 1 x Constant (battery)
Ive watched all the You tube vid sand understand the electrical principles but the fuse box is messing with my head.
Please help
There's one called ignition switch, which you can tap off for the ACC.
Then I believe the audio unit, instrument cluster & OBD2 port are all permanent live feeds.
Easy enough to check with a multi meter if you get stuck.
