Kuga Mk1 - 2010 Autolock (enable)
Has anyone managed to enable the autolock (drive away locking) on a 2010 Kuga ?
I've used ForScan to select enable but that has not turned it on.
  • 1 year later...
On 7/19/2021 at 9:49 AM, unofix said:
I've used FORScan to select enable but that has not turned it on.
Thought I'd answer my own post since I now know how it's done.
After using FORScan to enable the auto locking it has then got to be activated by a series of locking and unlocking using the inside little lock handle.
  1. Have the engine running.
  2. Switch off the engine.
  3. Turn ignition ON  - (do not start engine)
  4. Using the small door locking lever - Lock/Unlock Lock/Unlock Lock/Unlock
  5. Turn ignition OFF
  6. Quickly, using the small door locking lever - Lock/Unlock Lock/Unlock Lock/Unlock
  7. Turn ignition ON
  8. Using small door locking lever - Lock/Unlock
  9. Turn ignition OFF - Get confirmation 'Bing'
  10. Exit the Car - (electrics appear still to be alive)
  11. With keyfob - remote Lock the car
  12. With keyfob - remote Unlock the car
  13. The auto locking is now working. Doors lock at 5 MPH
Looks confusing but I just studied it for a few minutes before trying it and it worked first time 😀
  • 9 months later...
Hi, is this the same process to disable this feature (drives me crazy) and on a 2008 model?
