Battery light
Guys I need a bit of advice,I have a 2008 ford cmax 1.8 tdci,the battery light came on and I changed the alternator and then the battery,the light is still on,any advice is much appreciated.thank you
Ima be that guy…
have you checked that the battery has a good connection? No corrosion on the connectors/ and a snug fit?
The problem could be further down the line, but corrosion is a common issue for battery issues
Have you used a multimeter to carry out any tests ?
Voltage across battery terminals with engine off and car standing for 30 mins should be more than 12.5 Volt.
With engine on and running at a regular idle speed battey voltage should be at least 13.6 Volt.
Engine at 2000RPM battery voltage between 13.8V and 14.5V
  • 4 weeks later...
My brother had 2008 focus 1.8tdci.  It appeared the alternator was dodgy, but when fitting replacement we found the alternator waS not faulty. It was the alternator pulley that was faulty. It had a one way clutch in it which had failed. For anyone who is not familiar with this engine, the pulley is separate from the alternator and there is a shaft between the pulley and the alternator. Like this:https://www.ebay.co.uk/p/1709803765?iid=133338628813
