Escort Gti 1.8 Converting To Rs2000 Engine Need Help
Hi everyone i am geting a rs2000 engine it come from a j reg rs2000 and im puting it in my escort gti r reg i am geting the rs engine with gearbox ecu wiring looms power steering pump radiator inlet manifold and outlet manifold,
Will the rs 2000 engine fit straight in mine or wil the engine mounts be different? and would my exhaust fit on the rs2000 exhaust manifold? thanks for any reply's?
Not 100% sure but i think the mounts are the same, but you may have to use a different exhaust manifold
ok thanks do you know if the wiring loom is the same on the mk5 and six cuz think j reg rs2000 engine is a different mk than my r reg gti
Wiring loom is different and i would advise you swap it
im geting the wiring loom do u know if my exhaust will fit on the rs2000 exhaust manifold my car is a mk 6 and the rs2000 manifold is mk 5
