Replacing Driver Side Wing Mirror
Hoping you can help someone who doesn't know that much about cars...
So I'm trying to replace my driver side wing mirror on my C-max 2015 MK2.
I've removed the plastic trim around the edge of the window to expose the screws for the unit, but I can't trace where the connector cable goes to.
Is anybody able to shed some light on where I need to look for the connector? I'm hoping I don't have to take the door panel off.
I should also add that it's a manual fold, no heating mirror. Just standard electronic glass moving & indicator light.
Thanks,
Dan
The door mirror is held on from inside the car. Is this the plastic trim you have removed ?
Yes that's right. I'm trying to disconnect the electrics cable for it.
But can't seem to find where the cable goes to, it goes behind the door panel. I was hoping I wouldn't have to remove the panel to get to it.
I've got this far...
Yes, you do have to take the door panel off.
