Sync3 retrofit - factory rear camera problem
Hello everyone
I'm nearly on finish retrofitting sync3 to 2014 Ford Kuga. My biggest problem is factory reversing camera. I tried connect green Fakra connector (from coloured FCDIM screen) to APIM but I haven't got video (reverse gear activate it but is blue or black screen)
Camera signal is coming from this connector?
I really appreciate any help. I spend many hours for searching, and I nearly surrender for a while 😉
Matt
Silly question but have you reprogrammed the car and turned the camera on in the software ?
Thanks for your reply. I'm not checking this to be honest I was sure is active. I updated APIM As-Build data using donor car who has camera, also when I engage reverse I have a reverse screen -but is blue or black, without video.
I fitted a reverse camera to mine (not an original) and before I turned it on in the APIM settings, I also got a blue screen when I selected reverse.
Ok thanks I have a look today, and I let you know what settings I have programmed.
Ok I fixed it 🙂
I connect camera to wrong pins. It have to be like that:
  • 2 years later...
On 1/26/2022 at 10:49 AM, Mateusz said:
Ok I fixed it 🙂
Hi, sort of in the same problem, but you wrote: "I connect camera to wrong pins. It have to be like that" and that is exactly as the picture you posted initially:spacer.png
Yes. It's correct wiring :)
