Suspension problem nsf
Just had new suspension arm fitted for mot.
week later and it’s come apart. Cracked on hub joint behind wheel  at bottom.
Not sure what it’s called.
garage where it was done have offered to fit replacement for free if I can find one.
new from ford is scary expensive.
he called it a “steering knuckle/hub bearing carrier” not sure if that’s right.
I believe it’s actually called the “stub axle”.
any ideas for a replacement that won’t break the bank.
thanks.
To me the Stub axle is the rear as it is a fixed axle with bearing and hub that the wheel attaches to.
Front Hub/knuckle is right...the suspension arm ball joint goes in the bottom, shock absorber in the top, steering track rod end (ball joint) on the side and it all swivels to allow for turning.
Ford part diagram - item 1
Looks like a few choices depending on numerous things.
Ebay example   You'll need to find the right part of course.
I can't imagine that broke on it's own accord, probably why they will fit for free.
