Just bought a Mondeo - couple of questions
Hi all.  Recently purchased a 2007 1.8tdci zetc Mondeo with 63000 miles on it.
Firstly a/c doesn't work - hopefully just a re-gas ?
Secondly heated front screen doesn't work - the button illuminates but can't hear any relay clicking on/off or unable to see a dip in revs etc.  Any thoughts ?
Does this Mondeo have speed locking ? If so how do you activate.
Apart from that quite pleased with it, reset trip computer the other day and took it a run on C/C and seen 63mpg.
Any info / input appreciated
Cheers
Heated front screen is linked to external temperature. It will not operate if the ambient temp is above 7C
Some do, some don't. If yours can have it turned on you need to use the software FORScan
15 year old car? It's likely that the condenser has corroded - being where it is and what it's made of.
Thanks for replies.
Another issue - what should the speaker sound quality like on the mondeo ? at present the speakers sound crackly, distorted and all over the shop, is this the normality with the ford 6000 headunit ?
Should the fuel cap lock with the central locking ?
