Engine malfunction
I've got an 2010 2.0 tdci 140.290000 km (180.000miles)
In the display it have been comming with a fault. First something about fuelfilter, then engine malfunction. Changed filter, engine malfunction still on. In forscan is the codes:
P253F - Engine Oil Deteriorated Changes oil 9000km(5600 miles) back
P0670 - Glow Plug Module Control Circuit
P0380 - Glow Plug/Heater Circuit A
Any ideas??
I'm not sure what you're asking.
The DTC's are telling you to change the engine oil and fix the glow plug circuit. Have you done any of the things that are being indicated as having a problem ?
I'm asking if those errors would make the engine malfunction message, because those problems has been there for a short while, but the engine malfunction message is new.
The P0670 would turn on the EML
