running fault
vehicle starts in morning runs for about 2 miles then starts to jerk & judder like its running out off fuel, pull over turn ignition off then restart car will now run perfectly fine all day switching on & off. Until engine cools down then it will do the same as before.  after the initial re-start the engine fires up first turn of key every time  05 mk3 Mondeo 2.0 petrol zetec
poss temp sensor issue, cheap fix if it is.
And the first answer to most questions -- any codes showing
Changed sensor (ford part) NO faults or lights on dash, been suggested ignition fault. thanx Jimpster
