Location of Bluetooth module needed - KA mk2 2014
Help needed please. Have a power drain and flashing odometer issue, which Ford have diagnosed as a faulty Bluetooth module. They want to rush me £2k to replace it! Can anyone confirm the location of the module within the car? Some forums say the n/s door panel but I’ve removed both panels and cannot locate it.
On many Ford models (Fiesta / Focus) the separate Bluetooth module is located above the Glove box.
If you completely remove the glove box and look up under the dashboard you can clearly see it held in place in a metal bracket. I don't know if it is the same on the Ka
Sadly no joy, not behind or above the glove box. Anyone else have any ideas?
Yes mate bit of a pain but its in the rear passenger side door card.
Let me know how you get on, I've just disconnected mine but the odometer still flashing.
If you know of a fix let me know.
@Laidback1 Could you share a photo of the removed door card? I still can’t locate this thing.
  • 4 weeks later...
Sit in nearside rear seat and its the door card next to your left arm 😆
Take that off and you'll see through a hole its secured with a metal bar. I just disconnected mine.
Sorry didn't take any pictures
