Tracker
Looking to replace our tracker as company no longer operates
I need one that is very accurate and can be monitored by a app or website
any recommendations please , thanks in advance
I use a company called 'Rewire Security' and currently have 5 active trackers in use. Have used them for many years and found them to be very accurate, easy to install, and have the option of a remote output to control a relay (eg. cut off supply to electric fuel pump).
You can buy a tracker called DB1 LIte which is an excellent unit direct from Rewire Security for £59.99 https://www.rewiresecurity.co.uk/db1-lite-compact-gps-tracker-tracking-device
OR
You can buy the exact same DB1 Lite unit from Amazon who have it on offer at the moment for £29.99 https://www.amazon.co.uk/Tracker-Security-Motorbike-Tracking-Telematics/dp/B07B51D2HX/ref=sr_1_2?crid=172MT3UD7RJW&keywords=db1+lite&qid=1660504640&sprefix=db1+lite%2Caps%2C90&sr=8-2
Thanks .so the Amazon one is same unit ??
how do I set up the subscription etc ??
Says easy to fit ..is it easy to hide ??. Can it be found using a scanner ??
go to the Rewire Security site.
I also have a Rewire DB1, had it a couple of years now and also found it very handy for checking the voltage of the car battery especially during lock down when my car was hardly used. The position accuracy is very good. Mine accurate to about ten feet.
