Ford Ka Reverse light access + Replacement buttons help.
Hi, so I recently got a Ford Ka mk 2 Zetec as my first car. It's worked well so far, had a few odd issues with the gearbox but I've read it's a common issue with the gearboxes on these types of cars. My main question today is I'm wondering if there's any way to access the reversing light (to hook up a reverse cam which is also part of a dash cam setup) from the inside of the boot? And if not what would be the best way to approach installing a reverse camera.
My second question is, is there a cheap place to buy replacement steering wheel buttons for the KA? As many of mine are worn down. If there's a guide on how to add/remove them that would also be appreciated.
Thanks!
  • 5 months later...
Thanks!
Hi Did you get this sorted, just fitted mine, was simple, I can talk you through it if needed.
