04 2.0 mondeo
I have had a new alternator & battery fitted. But the battery warning light is on most times. Only off occasionally.
Any Ideas how to rectify this problem. I have checked battery connections & cleaned them.
Is this a brand new out of the box genuine Ford supplied alternator, or a reconditioned unit ?
Check the wiring of the small connector that plugs in to the alternator (2 or 3 small wires). They are prone to corroding and breaking. If there is not a good connection of the little plug then the charging system will not work correctly.
Also make sure that there is a good earth connection between the engine and the chassis earth point.
Take battery out and check/clean/tighten  earth connections underneath.
Could it be slipping alternator belt?
