ABS pump
My Ford cmax has recently had a replacement abs pump. This was 2nd hand and since being placed in my car the traction control light has come on. This has failed my MOT and the garage I use has been unable to diagnose, calibrate or fix the problem.
Ford themselves want £120 up front for a health check
any ideas on how I can fix this?
My tax is due end of the month and I can’t do it with a failed MOT
ABS modules are coded/programmed to the specific car. If you use a second had unit it will need to be programmed to your vehicle.
The ABS programming can only be done by a Ford main dealer or as far as I'm aware there are only two independent authorised  ABS repairers in the UK with the means to programme the units.
