cat converter only done 38,000 miles
my grand c max 1.0 has only done 38,000 and ford tell me that the cat needs replacing.
Why?  Is there another fault that's damaged it?
If it's a manufacturing defect, it should be covered under warranty.
The engine warning light appeared i took it to a ford dealership and they said the cat will soon need to be replaced.
its a 2016 car
5 minutes ago, BILL1948 said:
its a 2016 car
It's always hard to guess the problem when your profile details are not for the car with the issue.
33 minutes ago, BILL1948 said:
its a 2016 car
Ah, in that case it's not uncommon for the cat to clog up on the 1.0EB.
Low mileage means it's probably spent a lot of time in traffic rather than being driven on the motorway.
Thanks for reply ,ill try cat cleaner first to see if that cures it.
This works for a smelly cat.
  • 1 month later...
Well i got fed up resetting the engine light telling me the cat is on way out,so ive booked in to have it done nearly £900.00 for the privilege,whats next to go wrong.
