Sat nav
Occasionally it goes blank when the car is started, disabling the radio and phone operating
I presume you have SYNC 3???
That could be a problem with the ACM (Radio) too.
Delete Sync 3 from all your phones that are connected including Carplay etc
Perform a hard reset:
Turn on ignition but DO NOT start engine
Disconnect negative cable
Cover negative terminal on battery so it cannot make contact with cable
Disconnect positive cable
touch and hold together the positive & negative battery cables for at least 5 minutes, MAKE SURE they cannot touch the battery terminals
Reconnect positive then negative cables
Once car has powered up and started perform a master reset on the Sync 3 menu
In the sync 3 settings turn off Wi-Fi and automatic updates
Reconnect your phone.
See how you get on
If you still have an issue you may need to update the APIM (Screen) and or the ACM
