Headlight problem
I have a 2011 Mondeo Hatchback Titanium x sport which has a headlight malfunction. Headlights are working normal, cornering lights also OK but Forscan states Code: B1D65 Right Headlamp swiveling Motor Fault. Can this be repaired or will I need a complete headlight unit. Unfortunately, the current headlight has no part number label and no other id so struggling to know which headlight I would need if i would need to purchase from the internet. Don't want to pay Ford prices. Any help would be greatly appreciated.
VIN WF0EXXGBBEBL18860
This one for AFS (advanced front lighting system).  Part number 1835876.
Genuine Ford Mondeo Mk4 Front O/S Headlight Headlamp Unit 2007-2014 1835876 | eBay
These light clusters can't generally be repaired.  Ford don't supply the motors separately.  If you're confident with electronics you could strip the cluster down to see whether there may be anything obvious such as a loose connection that could be fixed with a bit of solder.
Thanks, I thought that, I have it booked into a ford independent garage next week, i will see what they say. hopefully if i need a replacement they can give me the part number for this unit because the old parts label has gone, so no way of identifying it.
