Ford Fiesta Mk8 - water pooling in driver footwell
Hi all,
have noticed today I have water pooling in my driver side footwell.
my car is fairly new, within the last 5 years so not due to rust, would anyone have any ideas, maybe a blocked scuttle drain.
thanks
Mine has water pooling in passengers footwell. Dealer checked and said not door seal, although it was loose. Said it was windscreen. Screen removed reseal and refitted. Next time it rained water in footwell again. Have now taken upon myself to re-stick loose seal. Suggest you check seal at top front edge downwards to see if it is loose.
Awesome thanks, will give a check this weekend. Only seems to be water collecting in the driver side, all other footwells are completely dry.
  • 2 years later...
I'm having the same issue right now on my 2022 fiesta mk8.5. the water seems to be under the carpet on driver side on the metal floor pan, did you get it sorted or find out where the leak was coming from?
Thanks,
Poppy
