p0135 (o2 sensor bank 1) code after replacing a new o2sensor
Any ideas on why it is throwing the same error after replacement and code deleting?
Does anybody have the wirediagram for the pcm to 02 sensor for 2011 galaxy 2.0 tdci?
That's the heater circuit on the sensor fault. So probably the fuse that supplies the heater circuit blown . Will get back to you on what fuse number and where.
Check fuse 6 , 10 amp. Engine bay fusebox
  • 1 month later...
Hi, fuse is
all is ok. Sensor works, but there was no power to the sensor. After a while there was power supply to it again...
Mechanic checked the wiring again and it was ok....
