MK4 Mondeo TDCI Fault Codes P0238 - P010F - P0098
Hi Guys my engine management light is on, 2.0 tdci 2008 mondeo, any idea what could be causing these codes guys? I cleared the codes and did a fresh scan so there is no old codes lingering.
Looks like a MAF fault.  May need a new one, or may be a wiring issue.
Thanks for your reply mate, i will remove it and clean it to see if it helps if not it looks like it needs replacing
Is the wiring problem common?
 Hi mate, using halfords contact cleaner i cleaned the 3 sensors internals and the external connectors, cleared the codes and it seems to have worked. Thanks for pointing me in the right direction
