MONDEO MK4.5 intelligent access key programming
Hello. Is there are any way to DIY mondeo mk4.5 2011 intelligent access key programming. As i understand immobilizer chip programming i can't do myself, because i need incode which is 80bits and there is no any calculator online to do this at a time, but how to program a remote lock/unlock function ? Methods with pushing start/stop button 4 or 8 cycles doesn't give any sound, which means i'm not in programming mode, how can i do this ? Reading information in internet 3 days, but no luck.
Programming the remote.
  • Sit in the car. Drivers door closed.
  • Do NOT put your foot on the brake or clutch pedals.
  • Press the ignition button as follows, within 6 seconds:
  1. On - Off
  2. On - Off
  3. On - Off
  4. On - Off
There is no, chime or sound.
Press any button on the keyfob.
There will be a chime OR the LED security light will flash to confirm keyfob programming accepted.
That method doesn't work, even 8 cycles on/off doesn't work as was suggested online.
