'98 Ka Steering Problem
Hi
'98 KA new steering rack, new bottom wishbones, new tyres
Odd problem, brakes in a straight line, drives fine up to 90 ish a little vague but only what I would expect from a car this age, no odd noises apart from the usual rattles of a 12 year old motor!
But over bumpy roads, minor potholes etc it seems to "fall off" to the right like dropping off a white line on a motorbike in the wet!
any info would be great thanks
i would check the rear sub frame
just infront the rear wheels is the part you need to check as the rubbers wear & it causes the problem your saying
do the following m8
open boot up & pull & push car from side to side
if any side movement you need to change the bushes
cost about £30.00 for a pair from fords
rear subframe bushes i think they call them
you will need to make or buy a puller to remove n refit them
i would also make sure the wishbones...lower suspension arms are tight & are fitted correctly
if they been done you should do them in pairs im my opinion
here is where i get my parts
www.buypartsby.co.uk
keep us posted on how you get on
