Engine light on
I changed air filter and got disturbed I didn't shut air filter cover properly. Now engine management light on. No fault on car. How do I reset engine light?
If there's genuinely no fault now, it should clear with an ignition cycle or a short drive.
If that doesn't work, you'll need a code reader to clear it.
Don't normally get EML for air cleaner lid.
Are you sure you haven't disturbed the MAF sensor?
Thank you both. I have driven 15 mile fault light still on unfortunately.
Where is MAF sensor situated?
Not sure which engine you have.  MAF is likely to be right next to the airbox outlet.
I have the 2.0l diesel 180.
Ok, MAF should be on the hard plastic elbow coming from the airbox in that case.  The plug is tucked in the corner of the airbox lid.
If not, post a picture of your airbox & intake pipe.
