O ring size heater matrix pipe connection
Hi all I have a 2013 cmax 1.6 petrol zetec. I have the dreaded wet driver side carpet coolant leak. I’ve stripped the dash panels away and got the 2 pipes apart. Does anyone know the actual size of the O rings for the heater matrix connection ? I’ve tried a few that looked similar but don’t quite fit. The old ones snapped when removed hence unsure
Ford are generally a creature of habit and so probably use the same O ring on your heater as they do on many others.
  • 1 year later...
Can you use silicone tape to repair this as a temporary solution?
