Bulb warning light after fitting LED’s
Hi
can anyone help
just fitted led headlight bulbs to my daughters car and everything seems fine apart from the warning light on the dash.
does anyone know how to remove this warning light or have I missed something??
cheers
You need CANBUS friendly LEDs.
Wrong type of LED lamps fitted. They need to be suitable for use on Canbus systems. Cheap, eBay and Amazon types are not suitable.
https://autobeam.co.uk/
Are you aware that the use of LED lamps on vehicles not originally fitted with them is an MOT failure in the UK ?
I don’t know where the term canbus compatible LEDs came from because there is no data communication with the bulbs. It’s mearly measuring the resistance. You could use the same LEDs with a resistor kit and it will stop the warnings.
All the cheap Chinese bulbs do that call themselves canbus compatible is stuff a resistor in to the bulb. Which then means they run hot and shorten the life of the LEDs.
