dashcam
can i leave my dash cam connected to the auxiliary out let whenever i switch the ignition off without it causing the battery to go flat. does it turn the power off after a short time.
Power socket (cigar lighter socket) turns off 20 minutes after the doors are locked. It will turn off sooner if the car detects the battery level is low.
thank you for your speedy reply,i will start to leave the dash cam connected.
