Heated rear window mondeo mk5
Hi my rear heated window has stopped working i have changed the fuse ,and still not working.Is the a relay switch for rear heated window ? Does it have one if so where is it located .i did read it is in the boot .I can not find it any advice would be fantastic
The Heated Rear Window relay is part of the Body Control Module (BCM) and is classed as a non-serviceable item by Ford. If you fully remove the BCM and open it up it will be possible to desolder the relay from the circuit board and replace it. Although in most cases the relay will not be the cause of the problem.
Check and/or replace Fuse F68 in the engine compartment fusebox (lower half)
I have changed the fuse
