door seal
Hey guys
i was wondering if any of you have had this problem or that can help me.  i have a mk3 Mondeo estate and my rear passenger door seems to have a leak but can see how its getting in but it just pools at the bottom then runs to carpet. do i need to replace the seal and if so does anyone know where to get one or the part number. as i have looked on eBay but not sure if its a direct fit or will cause leaking after fitting. any help will be greatly appreciated as I'm not keen on wet carpet smell after rain. plus doesn't leak when you go through a car wash just when it rains :s..
Probably should be another seal attached to door?
Check other doors to see if it's missing
That may be coming in through the door itself.  If you remove the door card I reckon the waterproof membrane behind it has been cut to replace a window motor then not resealed properly.
Also, Check that the drain holes in the bottom of the door aren't blocked
thanks guys will check all this, car in garage atm failed mot this morning so not on a good run 😞
Oh no!  What did it fail on...gotta save  them mk3s!
failed on rear wheel bearing,track rod has play, anti roll bars and my sun strip is too big
Please tell us that it doesn't have your and your wife's names on it!
Also... surprised the fluffy dice didn't trigger a failure, obstructing the driver's view
"Dave ❤️ Sharon"
Other names might be available, but I don't think so 🤣
At least it's a DIY fix!
8 hours ago, unofix said:
"Dave ❤️ Sharon"
No wife's name, or fluffy dice sadly 😞 . its just a deadly brand one with the letters cut out so i can see through them🤣 but that's not ok lol. may put back on after mot or go for a different one.
