Ford Edge Auto Lock
Does anybody know how to set the autolock feature on a 2018 ST Line Edge.
FORScan only, activate in BCM and IPC
The autolock feature will lock all the doors when:
  • all doors are closed,
  • the ignition is on,
  • you shift into any gear putting your vehicle in motion, and
  • your vehicle attains a speed greater than 12 mph (20 km/h).
The autolock feature repeats when:
  • you open then close any door while the ignition is on and your vehicle speed is 9 mph (15 km/h) or lower, and
  • your vehicle then attains a speed greater than 12 mph (20 km/h).
AUTOUNLOCK FEATURE
The autounlock feature will unlock all the doors when:
  • the ignition is on, all the doors are closed, and your vehicle has been in motion at a speed greater than 12 mph (20 km/h);
  • your vehicle comes to a stop and you switch the ignition off or to accessory; and
  • you open the driver door within 10 minutes of switching the ignition off or to accessory.
Note:   The doors will not autounlock if you electronically lock your vehicle after you switch the ignition off and before you open the driver door.
ENABLING OR DISABLING
Note:   You can enable or disable the autolock and autounlock features independently of each other.
You can enable or disable these features in the information display or your authorized dealer can do it for you.   See   General Information
Is that just copied from an American site?
Dealer can't and won't activate on EU spec cars, you must activate it yourself using FORScan, as mentioned above
NOT available on UK/European vehicles.
It has to be programmed using FORScan to make the feature available.
I included the source in my post.
Thanks all more money
You only need the lead, which is worth every penny. The software is free
