Headlights pointing down
So as title says headlights on my Mondeo are pointing down, I thought the leveling sensor would be all stiff but it did not seem to be that bad (apart from left/right angling)
Would anyone know how to investigate this? Like test the sensor for electrical failure etc, before I spend money either on new sensor or mechanic?
Thanks in advance
Use FORScan and a vLinker FS cable to plug in to the OBDII port and see if there are any error codes relating to the headlight leveling.
FORScan: https://forscan.org/download.html
vLinker FS cable: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
Thanks a lot. Will report next week as soon as I have received the cable.
I have received more errors than expected🥲:
B1A58:87-2F Right headlamp, headlamp range control motor
B1C98:13-6C Circuit of left cornering light, open circuit
B1C99:11-68 Circuit of right cornering light, short to ground
B1C99:13-6C Circuit of right cornering light, open circuit
It turned out ther was some water in the right headlight, so I took it of and trying to dry it.
Could i get some advice on how to deal with this?
Where is cornering light located?
