ford cmax mk2 cluster swap
just changed my cluster to the bigger screen on my mk2 cmax all seems to be working perfect but im getting two codes. can anyone help thankyou IMG_7923.thumb.jpeg.c9008912e72d4419215c4394705f96df.jpegIMG_7922.thumb.jpeg.24f5bfd5487fbf875645c3912a0a41d4.jpeg
Configuration conflict between the new cluster and what the car is expecting.
Download and install your car's original ASBuilt data
is this possible via forscan
Yes, you can use the 'AB' tab on the bottom of the FORScan configuration page.
Once you're connected go to config & Programming then connect to IPC
Once in, at the bottom will be a tab saying "Load Factory AB"
Click that, let it download then click "write all"
thankyou ill give this a try tomorrow
