IPC Communication DTC’s
I’ve had my car a couple of weeks now and noticed today there’s some sticky DTC’s logged.
Ive scanned with Forscan and cleared several times but they always come back.
Any thoughts of what is causing them?
U0073
U0140
U0159
U0100
U0121
U0421
The car hasn’t put up the EML (yet) and it seems to be running fine. I do have a slight suspicion that it isn’t accelerating quite as well as it should/could but I could be wrong on that.
Usually it would be poor solder joints on the instrument cluster, but very unlikely on a 2017 Kuga.
I'd remove the instrument cluster and check that the connectors are fully plugged in.
Cheers. I managed to find a guide on youtube (dead easy as you say).
So cluster removed, all was tight and the connector looked to be latched as it should be. Despite that I disconnected it and reconnected. I could hear the dials power up. Cleared codes, took it for a spin. Rechecked, codes remain gone. Hopefully that’s the end of that!
Thank you for your help.
