Trip Computer Poor Information.
Hello , i have an 2013 Ford C max and i have poor information on trip display.The information displayed is Trip(total km since last resset) and an average km/h.I tryed to program it with forscan and after i program it , it displays fuel to empty , but after i press any button on steerig whell it dissappears and the trip and average km/h appears again.Does any1 know what should i do so the trip computer show the speed , instant consuption , average consumption , fuel to empty , maybe digital speed....?Thanks !!!
Go into IPC again and at the bottom hit the button "load factory AB" let it download, then click "write all", car will be back to factory config.
ALWAYS save standard config, before you start messing, in case this happens
You haven't got the right level cluster to show the things you want
Hello Dave , i don't have other options in forscan.....cluster lvl is lvl 2 with trip computer and trip computer mixed units are mpl units with selection by driver.
Should be at bottom of IPC screen or Central Configuration
Hello Dave, unfortunately after i did load factory ab and did the write all , allot of errors came by.Had errors like child safety and pressure sensor....but i dont have pressure sensor in wheels.I did write back the backup i had , because with factory stuff , i also had allot of lights showing up on cluster.
You used to be able to download the asbuilt configuration from a Ford website, but I can't remember what it was or if it's even been took down.
I would recommend asking the question on the FORScan Forums, someone on there will be able to help you, or even contact FORScan support and see if they will help you
