Window Screen Wiper Issue
Hi, I have a 2016 Ford Ka and I have an issue with the fast continous window wiper setting.
It works normally when set to intermittent or slow continous, but when I was driving a few weeks ago it gave up when set to fast and will now no longer move (or if it does move it moves very slowly) on this setting.
Someone I know suggested changing the relay, but looking online I don't think my model has relays.
Just wondered if anyone might know what was up and if there is an easy fix I can try before taking it to a mechanic?
Check the switch, could be a dirty contact
Do they move at all when switched on ?
Wipers on wifes 2015 KA seized at the spindles.
I have put a full explanation on here somewhere. But basically stripped them down, cleaned the spindles, grease all the moving bits.
Rebuilt and all has been good.
A basic meter will tell you if you have voltage at the wiper motor connector. Just keep body parts away from anything that may move.
Thank you I will take a look and give them a clean
Most of the time they don't move at all on that setting, but on the odd occasion they do move it is very slowly and judders a lot!
Thank you I will have a look through and see if I can find your instructions!
From @Theshed
