Hi from wiltshire UK
Hi all.
name is Rob, ex mil based in Tidworth and needing some help and advice for my wee van,
hobbies are ham radio, golf and of course the van.
So looking forward to getting some help, giving some if I can and of course just the general chit chat about things that Connect us all.
Ok, this is it,
i am after some advice on tow bar wiring, I committed to buy a new tow bar and harness and got stuck in so followed the intructions to the letter and all went well until i connected the right indicator to the tow bar wiring and this happened.
the right indicator flashes 2 times very fast and then the relay stops ? With no more operation inc the left one, the ignition has to be switched off and on then try left and it does the same?
if i un plug the trailer the indicator lights all return to normal operation, (there is only an issue with the indicators all other lights are fine with or without the trailer attached),
normal wiring IE: to all cables and buzzer hard wired to the rear left lamp cluster down to the new tow socket ? Not a clue whats going on,
Just in case i have been sold the incorrect items may i ask if i need a can bus for a 2013 connect with regards to the above issues
apologies for the long intro, but i have been at it for well over 5 hours and still can’t sus this issue out,
cheers and again HI?
Rob.
Hi welcome
