Split in rear washer pipe
Hello! New here but need help. My daughter’s KA (2016) has a leak in the rear washer fluid where the pipe has split.
Luckily we found the split and would like to repair it, but I’m unsure if the size. I bought two different size rigid pipes from Amazon but both seem too small. Any ideas? The tube is ridged and externally seems around 5mm but it’s tricky to measure! I haven’t cut the pipe yet as I don’t want more fluid leaking in the car!
thanks, Nic
