Second hand dpf
Hi there is it a simple swap over ? The second hand dpf has the temp sensor and vaporiser attached or does a garage need to do it
Should be simple to swap as long as you're confident connecting the fuel line to the vaporiser.
The DPF differential sensor learned value should be reset ideally.  That can be done with Forscan.
Hi Tom don't have forscan don't know what it is🤣would a exhaust garage be able to help me out with that or can I buy it 👍
FORScan diagnostic and programming software for your FORD vehicle
On 4/7/2024 at 8:59 PM, unofix said:
Thank you very much UNOFIX👌👍
