Couldn’t find gears.
While returning home from the airport,  we had to come off the motorway and when I slowed down at lights I couldn’t get the car into any gear, I turned off the engine and waited for a few minutes,then when I turned back on it started fine, but it must be something and my wife is still wary about coming in the car now.
Then you better get it booked in to your local Ford dealer ASAP
The garage probably can't do much about that 🤣
It's most likely to be a clutch fault.  Either master cylinder or slave cylinder.  No easy way to determine which one, so I'd generally recommend starting with the master cylinder as it's a quicker & easier job than the slave.
