Ka 1997 Problems
My girlfriend has a 1997 Ka , There are a few problems with it so ill start with the first one. The air con is broken its fine if you want cold air coming out but when you put it to red for warm air it doesnt do a thing it still throws out cold air. What is the likely problem
sounds like your thermostat had had it's day to me
you should have cold air or warm air even if you dont have the air con running
i would check the thermostat 1st & replace it
about £8.00 ish for the part from ford.
if that's not it it maybe the sender unit
about £15.00 from ford.
i think your wording is a bit confusing, do you mean the heater fan?
if the fan is only blowing cold air then it may well be your 'heater control valve' its a common fault.
