Exhaust gas temperature bank 1 sensor 2
Hi, I have recently start having issues with my 1.6 TDI C-Max 2012. The warning light come on with the fault exhaust gas temperature bank 1 sensor 2, we replaced the sensor and was okay for a week or so but it has come back up with the same code. Would anyone have any ideas on what the issue could be or have had this issue ?
I'd try swapping over sensors 1 & 2 (pre & post cat) to see if the fault reoccurs or moves.  It might be that the new sensor is of poor quality.  Though there isn't much to a temp sensor, they're about as basic as it gets with sensors.
I suspect it's probably a damaged wire between the sensor and the PCM.  Can you remember what the fault code was?  Some codes specifically say 'circuit' in them.
