No GPS
Morning All,
new here and this is driving me crazy ok so my 2014 cmax it has been displaying no GPS and sat nav stopped working. So after a little research Found that it’s common issue with main aerial fine brought a car GPS and attached it to the gps port on the back of the screen. Brilliant Sat nav now works again but screen still displays No GPS I’m now at a loss any ideas? Many thanks in advance
Probably because the system is looking for the original GPS.
If it's working I wouldn't worry
Disconnect the negative lead from the battery for 20 minutes and then reconnect. It will cause a reboot of the system and should clear the issue.
I will try that when I can thank you
