ECU removel
I need to remove the ecu from my 2014 ford cmax. I have located the box, all stripped out, just need to know how to remove the security screws from the plastic box so I can get to the ecu itself. Any tips or do I brake the box and replace it once the ecu you is repaired or replaced.
Drill the heads off remove cover then remove the screw with a pair of pliers. You can buy replacements from ford but all I done was buy some bolts from screwfix M6 x 60mm and M6 washers if I remember correctly.
