Beeping
First time here.hope someone can help me
My mondeo mk5 2015 has got a beeping noise when i use the indicator without the engine on.and also when i put full beam on i get a beeping and aslo the dials light up
Any help please.
Common problem with the Mk4 Mondeo 2012 - 2014 is water ingress to the Body Control Module, caused by a design failure of the screenwash pump. There is a possibility that you have water ingress in the BCM.
On 6/29/2024 at 10:39 PM, unofix said:
Quite a common problem on a 2013 Mondeo. Normal cause is water ingress in the Body Control Module caused by a faulty designed screen wash pump.
