tyre pressure
what should the tyre pressure be ? my pressure was higher than what it say on the car sticker
The car sticker shows the correct tire pressure tested by £Billions of research from Ford. I suggest you set pressure on what your car states...
Just remember the sticker is cold tyre temperatures. They go up when driven or in direct sunlight.
In addition to one side showing different pressures depending on which way the sun hits the car...
ok ill set it to what car says just looks too low cheers
33 psi front, 28psi rear
well it was a lot higher than that
For an Ecosport?  Do they just 'look' heavy? :laugh:
There are usually two sets of pressures.  One for light load (one or two people) and another for full load (4 people plus luggage).  The previous owner might have needed it on full load setting.
fronts where at 40psi bcks about 39psi
Yeah that's about right for full load.  I've just checked the handbook.  Unofix is correct for light load.  Full load is 41psi front & rear.
TIRE PRESSURES
Tire size   Normal load   Full load
Front   Rear   Front   Rear
205/60 R16   2.3 bar (33 psi) 1.9 bar (28 psi) 2.8 bar (41 psi) 2.8 bar (41 psi)
205/50 R17   2.3 bar (33 psi) 1.9 bar (28 psi) 2.8 bar (41 psi) 2.8 bar (41 psi)
205/50 R171   2.3 bar (33 psi) 2.3 bar (33 psi) 2.8 bar (41 psi) 2.8 bar (41 psi)
215/45 R18   2.3 bar (33 psi) 1.9 bar (28 psi) 2.8 bar (41 psi) 2.8 bar (41 psi)
215/45 R181   2.3 bar (33 psi) 2.1 bar (30 psi) 2.8 bar (41 psi) 2.8 bar (41 psi)
1AWD.
TIRE PRESSURES
215/45 R181
1AWD.
cheers
