H
hello everyone I have replaced my gearbox mechatronic to a new one now I have an error code u0101 problems with lost communication with TCM and ESP light on the dashboard I have tested all fuses and cables everything is fine only at BCM module fuse f8 to f12 has no power, has anyone had a similar problem and solution for it, thanks
Check all the wiring from the transmission to the TCM is working correctly
hello, (Dave T70) thanks for your answer I have tested everything has a cable does not supply power it comes directly from (PCM) module to (TCM)
Hi welcome
hello thanks
